Happy Monday everyone,
Last night I drove my '76 for about 10 miles without any issues.
Today I started the car and it is running VERY rough. Last night and today the temperature outside was 55 degrees.
I can't figure out what would have changed over night with the car just parked in the garage.
I'll take a look at it after work tonight, but I'm not really sure where to start.
I hate to be such a newbie, but any guidance on what to check out is greatly appreciated.
Running Rough
- Your car is a: 1976 Fiat Spider
Running Rough
1976 Fiat 124 Spider
Re: Running Rough
It could be any one of a huge number of things. Did the timing belt jump a tooth. Fuel (delivery, carb, filter, blockage) Spark(check plugs, distributor, etc.) Air? Any loss of power? Sorry this is vague but I would revisit every aspect of the 10 minute drive for some clue and then get down to the basics of timing, fuel, spark, air.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Re: Running Rough
Thanks for the response TX.
I know I havent provided much info to go on. I'll know more tonight.
I doubt the belt jumped since it was running fine when I parked last night, but I'll check (if I can remember how).
Your right, I'll check the basics first.
Thanks again
Thanks again
- joelittel
Re: Running Rough
That’s great news.
Re: Running Rough
Well I spoke too soon.
It's doing the same thing again.
I checked the plug wires and they are all secure.
It won't even idle now though.
I tried to let it run so I could look in the engine compartment but no matter how far I pull the choke out it just sputters and dies.
Fuel filter maybe?
Fuel filter maybe?
Re: Running Rough
If you CAREFULLY pour a little bit of gas in the carb, and it runs (for a little bit), it's somewhere in the fuel delivery system. Else, it's probably ignition.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
- Your car is a: 1978 Spider 124 5 spd
Re: Running Rough
Hey Charlie, I had a similar sounding problem which ended up being the idle cut-off solenoid. The little pipe atop primary carb barrel was dribbling fuel out of it at an idle. The solenoid protrudes from (my) carb on driver's side and has 2 wires going to it. Even after changing elect. connectors it still didn't work. Slight pressure on those elect. connectors toward the firewall got it to work and engine running smoothed out immediately. Part is inexpensive - like $30 - $40.
Edit: copied from my post:
On left side of carb is a metal canister w/ 2 wires connected to it. Apparently this is called an ICU Solenoid, AKA Idle Shutoff Solenoid assembly. When my wrist put pressure on the connector towards the firewall, the engine ran very smooth. I replaced connector, cleaned male tab coming out of the solenoid and no difference, except still, if I pushed it a little toward firewall engine smoothed out.
You were on the right track Peter. I looked down primary barrel and when rough running there was fuel spitting out of accelerator pump nozzle while at idle. Favor the elect tab coming out of solenoid towards firewall and that stopped and engine running smooth. For now (until I can replace this part) I have tie-wrapped the connector with just a little pressure toward firewall. Just got back from an hour ride and car performed flawless. Yay!!!
Re: Running Rough
Thanks Justice,
I tried moving the connector at the solenoid but no luck.
However I did notice that if I unplug the solenoid and then plug it in with the ignition switch on, there is no audible click.
There should be a click...correct?
I did remove the carb and clean it up, including the jets and replaced the fuel filter. It starts right up now, but still idles rough.
I'm guessing the solenoid is bad but I'll double check the wiring to it before I replace it.
Thanks again
Thanks again
Re: Running Rough
On mine, I looked at accel pump nozzle while it was running and could see fuel dribbling out of the nozzle at idle. When solenoid working there is no fuel coming out of accel pump nozzle.
Users browsing this forum: Google [Bot] and 34 guests
