Hello,
I would like to freshen up under the hood.. And replace my oil dipstick.
I am a little backward on which one to get for my 78. There appears to be a short one (just the stick with gasket seal at block?) and a long one (with tube and mounting bracket to intake).
I am about to install Allison’s ignition on the block... will this stick be appropriate? I think this is the short version? Or am I backwards on this.
http://mrfiat.com/fiat-124-spider-1400- ... 66-78.html
Short dip stick question
78 Fiat 124
- kilrwail
Re: Short dip stick question
My original stick is the long one with the tube - with stock ignition. I don't know why you'd want to change that.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- azruss
I took my long one and cut it off. The seal at the top works for the bottom hole as well. I pulled the long tube and the dip stick and measured how much of the dip stick was sticking out of the tube and where the high/low marks were. I used a punch to mark the new high low marks. I also got the computronix with the "dizzy" for the block mount. I used the block mount cap and moved it to the head. Very happy with the results.
For anyone interested.. this stick works with a 78. Just pull the existing dipstick tube and replace. It’s that simple, same reading.
A must for anyone going the Distributor-less block mount.
Cheers
Fiat 124 Spider 1400 1600 1800 Engine Dipstick 1966-78 New https://rover.ebay.com/rover/0/0/0?mpre ... 1999289775
Cheers
78 Fiat 124
Users browsing this forum: No registered users and 38 guests
