Just installed a new fuel tank in a '71 Spider. Not turning over yet. Any tips??? Does the system need to be repressurized manually somehow?
I have one gallon in the tank. Need more to get her going?
New fuel tank
- Your car is a: 124 1971
Re: New fuel tank
Ok, quick update. The rubber fuel line from the tank has a leak. So that's going to get replaced before going further.
- AndyVAS
- Your car is a: 1980 Fiat 124 Spider
Re: New fuel tank
The more fuel in the tank the easier time the pump has.
Andy Phillips
Vick Auto - Technician, Performance Engine Builder & PFI Developer (with ITBs)
http://www.vickauto.com
Re: New fuel tank
Thanks much Andy!
Re: New fuel tank
I'd start by replacing every rubber component in the fuel system (especially the tank filler hose) and then go with a couple gallons. If electric, you can run it it manually for a minute or so to prime things up, otherwise just squirt some fuel in the carb throat to kick it off.
Re: New fuel tank
Going to start replacing the lines tomorrow. Thanks for the tip!
Re: New fuel tank
Gas in the carb fired it right up. Thanks again for the advice.
Re: New fuel tank
micktierney wrote:Gas in the carb fired it right up. Thanks again for the advice.
Just curious, how much did you put in the carb? I am about to experience this my self (entire new fuel system, from gas cap - lines - tank - etc - to new carb.
78 Fiat 124
Re: New fuel tank
Not much at all. I would say I put in about a "splash". Maybe about 1/4 cup.
Re: New fuel tank
micktierney wrote:Not much at all. I would say I put in about a "splash". Maybe about 1/4 cup.
Awesome! Thanks for the reply!!!
78 Fiat 124
- Your car is a: 1972 124 Sport Spider
Re: New fuel tank
Did you pour the fuel into the top of the carb through the butterfly valves or is there a way to fill the bowl without removing any screws? I've seen folks fill the carb bowl on other carbs, but can't seem to find a filler tube on our carbs. I have a 1972 with 1 2brl carb. I'm no mechanic, so please excuse my caveman speech.
Cheers!
DuganNukem
1972 Fiat 124 Sport Spider
2007 Audi RS4
2012 Volkswagen GLI
DuganNukem
2007 Audi RS4
2012 Volkswagen GLI
Re: New fuel tank
I'm planning on filling my carb through the fuel hose that the fuel filter is attached to. I also replaced my mechanical fuel pump and I'm not sure if I installed it properly. I watched a YouTube video on the installation but I'm not sure I had the aux shaft in the right position. I installed the new pump and had My GF crank the engine while I held my hand near the outlet on the pump to see if I could feel any air (lines are empty). I didn't feel much air at all. Should I feel short bursts of air?
I have also replaced all rubber hoses, removed tank, and blown out the lines with compressed air. Just wanted to make sure I could feel air being pumped by the fuel pump before filling it with fuel.
Cheers!
DuganNukem
2007 Audi RS4
2012 Volkswagen GLI
DuganNukem
2007 Audi RS4
2012 Volkswagen GLI
Re: New fuel tank
DuganNukem, your expertise level here is on par with mine so take the information from me here at face value. What I did was remove the air filter and pour a splash of fuel directly into the carb. But when it comes to the replacement of the fuel pump you should to start a new thread on that. Let the pro advice on that.
Users browsing this forum: No registered users and 56 guests
