EMPI 32/36 DFEV
- Your car is a: 1975 fiat spider
EMPI 32/36 DFEV
So I bought this carb Carburetor - Replacement - EMPI 32/36 DFEV and I'm having a hard time attaching the linkage does anybody have pictures of how they attach their's.
- davidbruce
Re: EMPI 32/36 DFEV
I have the older style linkage (not the cable) on my '73. I had to shorten the linkage rod (between carb stud and linkage stud). After doing this I found the spring that holds the activation rod in the bracket on the valve cover was no where near able to hold the rod in the bracket and it kept falling out. I put a flatwasher behind the bushing in the bracket and then marked the shaft with a sharpie just behind the washer. I removed the shaft and filed a groove around the shaft at the sharpie line. I reassembled everything and put a snap ring in the groove. That was a year ago and has been fine ever since.
Dave Kelly
Campbell River B.C.
1973 Sport(sold)
Campbell River B.C.
1973 Sport(sold)
Re: EMPI 32/36 DFEV
Thank you
Users browsing this forum: Google [Bot] and 14 guests
