Maybe a dumb question.
Does anyone know what the gap should be for the fuel switch in the AFM, I figure about 0.030". Should it be closer?
Is there a correct gap for Fuel shut off in the AFM
- Your car is a: 1981 2000
Re: Is there a correct gap for Fuel shut off in the AFM
Are you asking what the gap between the contacts for the fuel pump should be when the car is off? I haven't checked mine, but that sounds about right. If you hear the double relay clicking when you drive, or at idle, the gap is probably too big.
Kirk
Kirk
Correct the gap when car is off. Mine was touching and thus on all the time. I set it a few month ago very skinny and it closed again so I am going 0.030".
Gandy
Gandy
Users browsing this forum: No registered users and 21 guests
