Does anyone have a rough estimate (length) for the 5/16" (ID) supply and 1/4" (ID) return lines?
I would like to replace from fuel filter to tank on my 78 124.
Tank* you
Stainless fuel lines
78 Fiat 124
Re: Stainless fuel lines
Also - can someone please confirm:
5/16 supply = -5 AN
1/4 return = -4 AN
5/16 supply = -5 AN
1/4 return = -4 AN
78 Fiat 124
I needed about 13' each of 1/4" and 5/16" on my 1973 Spider. Your needs may vary depending on the routing; inside or underneath on your model. I used a copper/nickel alloy called Cunifer. Very easy to work with.
Thanks for the info above. I ordered all Russell braided lines...
Does anyone know the diameter for the 2-3ft of gas overflow / return hose?
78 Fiat 124
architect wrote:Thanks for the info above. I ordered all Russell braided lines...
Look's like Midwest sells them (12mm) - http://www.midwest-bayless.com/p-8119-4 ... ll-oe.aspx
78 Fiat 124
Users browsing this forum: No registered users and 48 guests
