new tank
sending unit
fuel pump
new filter
all new hoses from hard line to where ever
new gas
new clamps on hoses
blew air thu the main line and return line twice
took the fuel pump out, in stalled it ,seems to go in at the same stop and easy
but it not pumping,no gas
HELP thanks
fuel pump not pumping
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: fuel pump not pumping
maybe the "wherever" part is the problem
Did you prime the carb? The new lines are one long pocket of air. You'll need higher rpm in order to start flow.
- Your car is a: 1975 Fiat 124
I assume that you do not have an electric pump. I would use a little "starter Fluid" to get the motor
going long enough to get the fuel lines and the carburetor bowel full. Just a little squirt goes a long way.
Repeat until engines run on it's own.
A large fire extinguisher on hand is a good idea.
SAMAKIJOE
AKA GRANDPA GRUMPYPANTS
Well. I need a new carb, so I'm getting that then I will start over and get it running
I'm going to add a new starter too
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1971 128
Did you use a clear filter or run the line from the carb into a container to verify there is no gas flowing to the pump? Make sure you have the hoses the right way on the pump, 50% chance to get it backwards. Forget the carb or the motor until you have gas flowing out of the pump......this is all assuming an electric fuel pump is being used.
Mechanical pump
I got the hoes right
I hooked up a electric to see if it flows, it does, but I'm going to use mechanical
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Jim said:
Mechanical pump
I hooked up a electric to see if it flows, it does, but I'm going to use mechanical...........
hoes?,.. did you say hoes??? Lucky you don't have a talk radio show. Or do you??
Mechanical pump
SAMAKIJOE
samakijoe wrote:Jim said:
Mechanical pump
Didn't you know that Jim doubles as talk show host Don Imus on his spare time from Fiats?
http://youtu.be/x1lnl-xD6iE
Lol no talk show
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Sounds like the pump is not working. Try removing the pump and working the lever arm by hand to see if it moves gas, could be the new pump is defective, I guess.
Users browsing this forum: No registered users and 42 guests
