Air filter mounting stud hole stripped
Texafornian
Postby Texafornian » Sun Mar 26, 2017 7:38 pm
On my 77 Spider single carb, one of the four holes where the mounting studs screws in is stripped out. Three others are fine. Can I live with it, or is it urgent to fix? If so, what are ideas for how to fix? It doesn't seem like a complete carb replacement is warranted. It is the lower left hole if you are on the driver's side looking down at it. Thanks for your advice!
Daniel
Re: Air filter mounting stud hole stripped
Postby AriK » Sun Mar 26, 2017 7:52 pm
I bought a length of stud and cut it to size. I secured it using 2 nuts on the underneath. I hate that design with those little bits at risk getting sucked into the carb. Be sure to tighten accordingly and use a threadlocker on especially on the top nut.
Ramzi
Your car is a: 1972 Fiat 124 Spider
Postby Ramzi » Sun Mar 26, 2017 9:32 pm
I think I may have a couple oversized studs that we were looking at putting into production. Email me directly on Monday and I'll make you a deal
R
Ramzi
1939 Fiat 508cm Coloniale (military)
1939 Fiat 508c Coloniale (civilian)
1966 124 Sedan RHD (oldest 124 in America)
1972 124 Spider GCRE (modified 2.0L)
2017 124 Spider Abarth (highly modified)
Texafornian
Postby Texafornian » Mon Mar 27, 2017 10:19 am
Thanks Csaba, I sent you a note!
Daniel
Return to “Engine and Tuning”
Users browsing this forum: No registered users and 19 guests
