Cam box gaskets
njoconnor
Your car is a: 1972 124 Spider
Cam box gaskets
Postby njoconnor » Fri Mar 24, 2017 8:17 pm
A week without snow here in Madison, and thoughts turn to the Blue 72..... :)
Last summer I (finally) changed out the gaskets for the cam covers (clean plug wells....what a luxury!). I intended to also do a complete shim check, but....well...things got busy. I have a partial order at one of the vendors, and was wondering: If I pull the cam covers again this spring, is it best to use new gaskets on the reinstall, or can I use the year-old ones? The covers were tightened to the "hand tight and a quarter turn" specification, so no excess pressure. TIA.
Neil
PS: Pat and I are registered and reserved for the 2017 Freakout in Milwaukee. We arrive Thurs AM and (probably) head right to Holy Hill with the entourage. Looking forward to placing faces and names (and cars!) together!
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
klweimer
Re: Cam box gaskets
Postby klweimer » Sat Mar 25, 2017 8:40 am
I would start by reusing the ones you have. Easy enough to replace later if they seep. I would make sure to keep the orientation unchanged from as installed originally. (front/back, right/left, up/down)
Kirk
njoconnor
Re: Cam box gaskets
Postby njoconnor » Sat Mar 25, 2017 9:15 am
Thanks, Kirk! Think I'll still add a set to the pending order. That way there's no delay if the seepage starts again.
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
Re: Cam box gaskets
Postby RRoller123 » Sat Mar 25, 2017 7:32 pm
klweimer wrote:I would start by reusing the ones you have. Easy enough to replace later if they seep. I would make sure to keep the orientation unchanged from as installed originally. (front/back, right/left, up/down)
Kirk
+1 on that, because they take a set, and you can see the outline of the cover impressed in the used gasket. I have reused them with no leaks, but make sure they are clean, as any piece of grit might cause a small leak. :?:
Return to “Engine and Tuning”
