Misfires and dies when hot
- Your car is a: 1982 124 spyder
1982 spider rebuild engine and ran well for 18 months Now I'm good for about 10 miles then she turns psycho. Misfires sees at the lights and seems worse with more than 1/4 throttle When cold starts perfectly and idles perfectly when warmed up then cya le will repeat itself I have New Fuel filter; new plugs HT leads and ignition module and coil . I can hear full pump running when I switch on . Where should I look next ? Chris
- 81SPIDERMATT
Re: Misfires and dies when hot
attach a fuel pressure gauge to confirm pump is doing its job when it acts up ... not cold when all things are good .... you can "t" one off the cold start injector and run gauge under hood and hold it down with windshield wiper while driving ... when it starts to act up keep a close watch on the gauge ... been a while but I wanna say 30 plus pounds is what we want ... maybe someone can chime in and confirm proper pressure for the pump ... Matt
Also check for a sticking AFM door flap. It may be doing this after it warms up under the hood.
- Your car is a: 1982 Fiat 124 Spider
Couple of thoughts: 1. is the ignition timing correct? and 2. Is the Coolant Temperature Sensor working correctly?
Thanks gentlemen Will get these things done and let you know . I forgot in my list yesterday that I also have a new Distributor cap and pick up module.
Coolant sensors gone AWOL make sense so I will check these .
I know fuel pressure "running in the garage" was a good 35psi
Has anyone ever had a new Ignition module go bad on them ?
I remember seeing an AFM fix that involved shifting the track of the "sweeper" inside the AFM - I w as wondering about that - does anyone know the link ?
viewtopic.php?f=9&t=20792&hilit=adjust+afm+wiper
Here is one thread about the AFM. There is a manual, and a better description somewhere regarding bending the AFM wiper, and if I can find it I will post it here. The basic idea is that you loosen the lock hardware that holds the wiper in place, push it slightly down on its vertical mounting arm, and retighten it in this new position. This forces the contact point further out onto fresh TFM (thick film resistor) material, and gets the contact point out of the wear tracks. The wear tracks are easily seen once you take the top off and look inside. Move the flap , manually, and it will be clear how the wiper sweeps across the TFM. This is surprisingly easy to do; there is no need to be intimidated by it, and it typically makes quite a difference in idle and performance across the RPM range!
Pete
Pete
An update on this issue I found some cracked connectors ( cold start valve and temp sensor at the "Tee" ) but no improvement Had the car taken to the wizard and he thinks its a buggered Air Flow Meter. Waiting for one to be shipped from the US and will let you know Should d I have thrown out the injection and gone back to a Weber ?? Catch the next episode .
- 81SPIDERMATT
sweet you have a wizard .... cant say never had a carb on the fiat .... love my FI .... driving around here there can be thousands of feet of elevation change ... other car is an old scout ...someday it will get fuel injected also .... carb gets quirky as I head up into the hills ..... keep us posted ...Matt
- Contact:
There have been a few posts here where people installed new ignition control modules and and experienced similar problems to yours. Some had issues with car starting when up to temp. I have had no problems with the ignition control modules manufactured by "Standard Automotive Products" Part Number LX301
- 81SPIDERMATT
curious ... how goes the battle ?
Users browsing this forum: No registered users and 30 guests
