Torque for oil pan bolts?
I guess its normal but I noticed a little oil seeping out of the oil pan gasket. I checked the oil pan bolts and some seemed a little loose, I tried tightening them a little bit decided to ask here first before I overtorqued them. I looked in my book but couldn't find the torque for the pan bolts. Anyone know? Thx.
- kmac33
- Your car is a: 1974 Spider
Re: Torque for oil pan bolts?
I wouldn't go above 8-10 ft/lbs.
Kevin McMullen
1974 Fiat Spider - Restoration Complete! But the mods/refinements continue
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
- Your car is a: 1984 Azzurra
I was just doing mine to 10 and snapped one. going to go lighter this time and tighten later if needed.
The maximum toque for a 8.8 grade 6 mm bolt, oiled is 69 inch pounds or 5.75 ft pounds. I don't remember the grade of the oil pan bolts.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
Users browsing this forum: No registered users and 37 guests
