1980 FI Timing Marks
slflynt
Your car is a: 1980 Spider FI
Postby slflynt » Sat Apr 21, 2018 12:08 pm
Hello, would anybody care to look at the image below and tell me if I am just blind and not seeing the timing marks or is that protrusion supposed to be used in some way? Thanks in advance! :?
ORFORD2004
Re: 1980 FI Timing Marks
Postby ORFORD2004 » Sat Apr 21, 2018 12:15 pm
My timing mark on my 83 is on the passenger side.
You can also remove #1 spark plug and put a screwdriver in the hole. Put the screwdriver to the highest point and you are at TDC.
slflynt
Postby slflynt » Sat Apr 21, 2018 12:30 pm
Oh, is it the metal thing with the teeth??? :o
ORFORD2004
Postby ORFORD2004 » Sat Apr 21, 2018 6:31 pm
Yes, now you need a timing light. 0-5-10 from the top.
Also, unplug the vacuum hose from the distributor and plug it.
Idle 850-900 RPM
PhillySpider
Postby PhillySpider » Sun Apr 22, 2018 2:24 am
ORFORD2004 wrote:Also, unplug the vacuum hose from the distributor and plug it.
Can you explain this in some detail as to why and what gain?
ORFORD2004
Postby ORFORD2004 » Sun Apr 22, 2018 8:47 pm
It was not in the book but if I remember properly, it was to be shure that the vacuum did not put some advance on your timing.
Return to “Engine and Tuning”
Users browsing this forum: No registered users and 24 guests
