1982 spider -- slow signals when brakes are on.
Does anybody know why this happens?
OOPS sorry wrong board..
- Your car is a: 1982 Fiat 124 Spider
Re: 1982 spider -- slow signals when brakes are on
Voltage drop due to bad grounds is most likely cause. Check the two ground pods on either fender, the pod under the driver's side dash, and the ground cluster at the driver's side rear tail light. Start by cleaning and tightening all the Fast-On type connections.
Return to “Off Topic & Social”
Users browsing this forum: No registered users and 31 guests
