I purchased a 1975 (Pagoda yellow!) spider on Friday and drove it 50 miles home, it is a bit of a barn find that I am looking for ideas on - I am thinking of doing a more “bare” interior.
I have pulled the carpets and mats, scraped up the tar that coats the pans and am in the process of sanding to bare metal. My plan is then to use Evapo-Rust, and then either POR-15 or truck bed liner.
Has anyone here used bed liner for the floors?
I have a fair amount of experience using it, and was thinking if I decide to run without carpets that this would be a durable solution
Thanks in advance!
Bed liner for floorpans?
- Your car is a: 2013 Abarth
Re: Bed liner for floorpans?
I see no reason why this would not work, but you'd be surprised how much heat comes off the transmission tunnel, even with insulation and carpet. The 1975 model does not have cowl vents like the earlier cars. It may get a bit toasty in there.
- Your car is a: 1969 Fiat 124 Spider AS
I am in the same process. I made the decision to use an acrylic black paint and then will have 2 layers of sound proofing (sheets first) and then a roll of insulation above that. I see no reason not to use the bed liner. Just make sure it adheres to the metal well. I used POR-15 in other places on my car.
1969 Fiat 124 Spider AS0012768
I used spray on bedliner, but started rust free. It is tough as nails, and completely seals everything. No water will intrude past it, just like in a truck bed. And it won't get chipped under the insulation and carpet.
- Ptoneill
At SEMA I saw a product called Lizard Skin that acted as a heat barrier and sound dampener, pretty decent reviews and is a do it yourself application.
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
Users browsing this forum: No registered users and 47 guests
