Veglia Borletti clock repair
- Your car is a: 1972 Fiat 124 Spider
I am sure I saw a recent posting offering the repair of Veglia Borletti clocks. Thought it was under Restoration Projects. Can anyone point me to this or whom I might contact?
- Patron 2021
Re: Veglia Borletti clock repair
The vendor is in parts for sale search clocks
- geospider
I believe: Palo Alto Speedometer
http://www.paspeedo.com/
Just talked to a watch repair guy about this today
- Yadkin
- Your car is a: 1974 Spider
All I did with mine was cleaned it wit compressed air and applied a small amount of lube that I use for the slider mechanisms on my inkjet printers: working. I'm sure any clock clock repair guy can fix yours.
- Nanonevol
Mine also just needed a nudge and a drop of thin oil.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
Thanks for the replies! I really appreciate DIY suggestions. Is there a method to removing the front bezel without bending it unnecessarily?
- Nanonevol
No. (joking!) Maybe someone knows how but I used a dremel part way around the back edge until I could get the front off and then used
JB Weld to put it back together. Not optimal but it got the job done.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- nelsonj
Here's my write up:
Hurray - I finally fixed my clock glass.
Well, I started with a broken donor clock that had clear glass. I used a small screw driver to pry back the aluminum ring. Very slowly all the way around. Then I used a slightly larger screw driver and repeated the process, and then removed the outer ring. I then took the clock apart to try to get to the gear behind the "set knob". But, I broke the tip of the setting stem off in the process. Good thing this was a broken donor clock. Anyway I was able to slide the glass off.
Here is a picture of the clocks innards.
I then repeated the same process with my working clock to get the glass out. However, the internal design of my working clock was different. I was able to remove a very tiny retaining washers, and then remove the setting pin, and then remove the glass. Here is a picture of the old glass.
I swapped the cloudy glass for the clear, and then re-assembled my good clock. However, I was not able to get the tiny retaining washer back on the setting pin. However, it did not seem to impact the clock at all, so I think I am ok.
And finally - my new glass!!!
wow - it makes the dash look new, but now my other gauges look old. Oh well - my clock is cool at least.
Simi Valley, California
Spider 1800
Romans 10:9
Users browsing this forum: No registered users and 57 guests
