Rocker install
- Your car is a: 1981 Spider
Rocker install
Rockers for my '81 are painted up real nice like and I'm ready to put them on and I have no idea what screws when where. My memory: screws (and maybe some rivets?) held it onto the threshold of the door and screws on the bottom and a bolt/nut at each end. Did the bolts have some rubber something in between the rocker and the body? Other suggestions for how to install these will be most welcome.
- Your car is a: 1971 + 1972 + 1979 Spiders
Re: Rocker install
If you don't have the original fasteners, three stainless #8 screws into plastic grommets along the door baseline, covered by the chrome step plate. Three more #8's with washers along the bottom. A 5mm nut and large washer at the rear, and another #8 Pan Head at the front.
Users browsing this forum: No registered users and 37 guests
