Please help identify
blazingspider
Your car is a: 1977 fiat spider
Re: Please help identify
Postby blazingspider » Tue Jun 27, 2017 6:54 am
Mine has the 3-way part, with the 3 hoses in and 1 out, but it is smaller and works as a fume collector (and assumed liquid separator).
Maybe he has a sealed replacement cap when a vented cap was original on his configuration? :?:
Any spider that came with an evap emissions system did not come with a vented gas cap and they also have a 3 to 1 fume collector in the trunk.
The schematic for the carb'd version of the evap emissions system is quite a bit different than the one for the fi cars.
The fi cars have that check valve underneath the car and no 3 way valve in the trunk. The carb'd cars have the 3 way valve in the trunk with no check valve underneath the car.
Make up air in a carb'd car is pulled from a small orifice built into the body of the 3 way valve. Make up air for fi cars is pulled from the charcoal cannister.
Nanonevol
Postby Nanonevol » Tue Jun 27, 2017 10:00 am
Can anyone explain why there would be 3 hoses coming from the tank merging into one hose (see RRoller's diagram and my photo at top of thread)?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Postby RRoller123 » Tue Jun 27, 2017 11:49 am
Probably to provide enough volume for the fumes to condense into a drop and flow back down into the tank? It only makes sense if it has something to do with a minimum necessary volume in that section of the line, as there is no anti-tip-over leak valve or anything like that there.
Users browsing this forum: No registered users and 38 guests
