I have this horrible screech occasionally when I first start the car. It may continue sporadically for a mile or so but goes away once I'm warmed up. I've done some snooping around underneath but see nothing obvious. Please listen to this and see if it's anything anyone recognizes. It's the noise you hear right after the motor catches.
https://drive.google.com/file/d/0B9_p6T ... sp=sharing
Horrible screech
- Nanonevol
Horrible screech
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- kilrwail
Re: Horrible screech
Sounds like a loose alternator belt. Check the "play" available when the engine is off - should be about 1/4 - 3/8".
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- spiderdan
- Your car is a: 1968 124 Sport Spider
kilrwail wrote:Sounds like a loose alternator belt.
Agree with you Peter.
If play is good I would replace the belt to see if the sound goes away. Some belts over time can develop a "shine" which can cause a slight slip and a squeal. As they warm up they get a better grip.
Dan
"Angelina"
2015 Toyota Camry XSE (hers)
"Angelina"
- Nanonevol
That would be great if it's that simple. Just had the belt off for a new radiator and water pump. I'll let y'all know when I get a resolution. Thanks
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
I usually need to put the wooden handle of a hammer behind there as a small lever to get the belt tight enough.
- Nanonevol
As they say at Staples, "That was easy". Thank you all. Sure did sound awful before.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
Users browsing this forum: No registered users and 31 guests
