I've got Hushmat kits in stock now. #1 rated product for thermal and sound insulation. Door, floor, trunk and hood kits are available along with undercarpet foam. This will cure your hot tunnel/floor problems!
Hushmat
- So Cal Mark
- Your car is a: Fiat
Hushmat
Mark Allison
Re: Hushmat
Do you have kits for just the floor?
- So Cal Mark
Re: Hushmat
I have kits that contain 12"x23" panels. I'll be getting some larger panels, but at the moment the 12x23 is the largest panel I have in stock
Mark Allison
- Your car is a: 1978 Spider
Re: Hushmat
Mark,
It looks like I am going the Hushmat route. Any idea on what kind of square footage I'm looking at to cover the entire passenger tub area of the car?
Looking to do:
Footwell and firewall as high up under the dash i can go
Side kick panel area
All of the transmission tunnel
All of the floor panels
Vertical part of door sills
Rear seat cross member
Rear seat area and up the sidewalls and rear wall area
50sq/ft?
Looking to do:
50sq/ft?
- So Cal Mark
Re: Hushmat
Hushmat has done some templates to calculate sq footage and here's what they've come up with;
firewall, floors on both side, front tunnel (shifter fwd), rear tunnel (shifter rearward), rear seat area
totals about 44 sq ft. If you want to do side panels and sills you'll need to add some to that total
Mark Allison
Users browsing this forum: No registered users and 38 guests
