It sounds like a noisy tappet...closest to the firewall... that lasts only for few minutes until it's warm.
This just started. Is this unusual?
Jim
Noisy tappet
- wetminkey
Re: Noisy tappet
I'll venture an answer,...
Yes, Jimb, it is unusual.
Sounds like you may have developed excessive lash in one of your valves. The sound disappears as the parts warm and expand,...
Just my guess.
You could check your rear valve clearances,...you may need to swap for a thicker 'tappet plate' on one of your valves.
I hope this helps! Good luck.
Todd.
Just my guess.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- Your car is a: 1982 Fiat Spider - Lip Stick Red
Re: Noisy tappet
On mine it was due to sticky valves, valve guides and tappets.
I added a bottle of Marvel Mystery oil in the oil at oil change and also a bottle in the fuel tank at fill up.
The noise went away after 300 to 400 miles of highway driving.
1982 Fiat Spider in restoration
- wetminkey
Re: Noisy tappet
I absolutely agree with Fiatracertracer,...Marvel is certainly worth a try. It's good stuff and will not hurt your engine. Sure hope it will solve your tappet noise! Good luck.
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Users browsing this forum: No registered users and 74 guests
