Is it possible without tearing the dash apart to have to get behind it?
Jim
How does one remove the electric window switch on an 85?
- Patron 2019
- Your car is a: 1985.5 pininfarina
Re: How does one remove the electric window switch on an 85?
Not that I know of. The clips have to be pressed from the back. A alternative to removing the center dash plate is to carefully remove just the row of switches. It pries out fairly easy, just be mindful of the tabs catching on the plastic "wood" veneer.
- Your car is a: 1984 Pinanfarina spyder
- Contact:
Hi ekstrandt, I have an 84 and have done several times, first remove the radio. This gives you hand access from the back.
with your hand push out the switch in the center panel from the back. And if you ever have to remove the bezel, first remove all switches from the back.
Victor
Victor
1971 MGB Roadster (sold)
1977 fiat 124 (sold)
2010 Prius
2001 Sequoia
2006 20' REgal bowrider boat.
1984 Pinanfarina
2010 Prius
2001 Sequoia
1984 Pinanfarina
Great advise!
Thanks guys,
Jim
Thanks guys,
Jim
