Replacement dash cover
focodave
Re: Replacement dash cover
Postby focodave » Fri Feb 02, 2018 4:36 pm
Hello:
I also have the hard black plastic one bought many years ago from IAP and it does look good except after a few years it developed a small sag. I had to go back and trim the glove box door to get it to close. Sag does not appear to have gotten any worse since then.
Huh.
I've had mine installed for about 4 years, now.
No warps, sags, bends, discoloration, and no change in appearance from when I first installed it.
My car sits in my attached, but unheated, garage and regularly sees seasonal temperature swings of about 30 degrees F to 110 degrees F.
1970 MGB GT (my other hobby)
wetminkey
Postby wetminkey » Sun Feb 04, 2018 11:53 pm
I've requested an estimate for a rebuild of my '79 Spider 2000 dash from justdashes.com. More when I get a response.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
wetminkey
Postby wetminkey » Wed Feb 07, 2018 4:56 pm
OUTRAGEOUS is right!!! How about this estimate from Just Dashes:
"Our current lead time is approximately 10-12 weeks from the time we receive your parts.
Here is an approximate cost of your restoration:
$1,100 | Dash
Other Parts:
$500 | Console between seats
**Please lis shipping zip code for estimate**
$100-$200 Color Match Fee
*No extra charge for black
+ Shipping"
I sent them a nasty-gram back to shame them, and will be shopping fro a full, padded dash replacement.
I'll post more as things progress,...
This is NOT my first rodeo!! That price is insane!
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
FiatJim
Patron 2023
Patron 2023
Your car is a: 1973 spider refurbished
Postby FiatJim » Tue Feb 13, 2018 8:17 pm
I had a black plastic dash cover installed by a vendor. Unfortunately, the installer did not do a complete job and the front middle edge buckled up in t 2 spots. So, my advice, try to get a few referrals from previous customers before you proceed.
I am using a dash "rug" to cover it up.
Jim
NorthernOtter
Your car is a: 1973 Fiat 124 Spider
Postby NorthernOtter » Thu Feb 15, 2018 1:10 pm
Spoke with a local upholsterer that has been doing work since 1975. He said that installation is a big factor in the durability of the caps, and that they should be installed with a bead of sealant around the edges, leaving the rest "floating". If it is glued down in all areas, there is no room for flex and cracks will develop.
wetminkey
Postby wetminkey » Fri Feb 16, 2018 12:55 am
I've replaced multiple dashes in 'classic' cars with new, urethane, full dash replacements.
They excel in appearance, ease of installation, fit, and durability. The urethane is unaffected by UV or heat and does not change shape or warp. Colors do not fade.
Each of them has cost several hundred dollars, and shipping has not been cheap. I would say they have cost me about $300-$350 each,...but they are a permanent replacement.
I have put a lot of research into this subject and read a lot of opinions of folks that have opted for dashes and caps. I think the new urethane dashes are worth the cost. I hope this helps to make that painful dash replacement decision easier! Good luck!
Todd.
P.S. On request, I can provide pics of most of the dashes I've installed,...
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Users browsing this forum: No registered users and 62 guests
