Thanks, Pete! Still think I'm going to toss a couple of ounces of ZDDP into the mix next oil change, though.....
Neil
(PS: probably just bought the last two CJ gallons in Madison, WI!)
"Diesel" oil
- njoconnor
- Your car is a: 1972 124 Spider
Re: "Diesel" oil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
Madison, WI
72 FIAT 124 Spider
Re: "Diesel" oil
They didn't specifically say that they have substituted environmentally damaging zinc with other more benign anti-wear additives, but that seems a reasonable conclusion.
- SP3
- Your car is a: 1966 Ducati 250 Monza
Re: "Diesel" oil
RRoller123 wrote:They didn't specifically say that they have substituted environmentally damaging zinc with other more benign anti-wear additives, but that seems a reasonable conclusion.
more likely they've only reduced the amount. but, it will still have more than the average gasoline engine oil.
Re: "Diesel" oil
Could be. Someone should ask then that direct question. And I wonder.... has the PPM level of Zinc that we need for cam protection been generally established?
- kilrwail
Re: "Diesel" oil
I see that I'm quoted in here based on a conversation at FFO, so I'll chime in. LN Engineering, which is a Porsche specialist manufacturer, wrote a paper a few years ago on this topic. From memory, the recommended levels of both zinc and phosphorus required to protect flat tappet engines was 1200 ppm. I use Brad Penn 20W-50 in both my Fiat and Porsche and have for close to ten years, based on the recommendation of my engine builder and the LN paper. It's the former Kendall GT green oil and is popular around here with NA hot rodders as well. No additives are required and it's convenient to use the same oil in both cars.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
Re: "Diesel" oil
http://rotella.shell.com/products/pc-11.html
Here is their web site data on the CJ-4 to CK-4 change; I will write again and ask them directly what the Zinc level change is, and have they added replacement anti-wear additives to account for the lower Zinc. (?)
Let's go with your 1200 ppm Zinc spec for the time being in this discussion. Good stuff.
Re: "Diesel" oil
I just sent them this inquiry, we will see what they say:
"I would like a little more clarification on the change from CJ-4 to CK-4 15W-40 Diesel oil. We use it in our Fiat 2L OHC/V flat tappet older engines for its Zinc content, to reduce Cam lobe wear. I understand that the Zinc content has been reduced. What is the new PPM of Zinc in the CK-4 formulation? Have new anti-wear additives been added, or existing ones increased (that are more environmentally friendly), to make up for the decrease in the old Zinc content? Thank you!"
(Again, this is to the Shell Rotella Business Group. The best way to get a quick response from them seems to be via FB. Each group has its own customer service contact organization, and I think a separate FB page as well.)
Re: "Diesel" oil
Here is the response I just received from the Shell Rotella Business group regarding my question (below, earlier post). As far as I am concerned, the case is entirely closed and the Shell people are acquitted.
"Hi Peter, the zinc levels in the new formulation have not changed - they are still around 1200ppm."
Pete
Pete
- kilrwail
Re: "Diesel" oil
The LN Engineering paper I referenced above is (in my opinion) the definitive piece on the subject. It includes a ton of theory and a table listing all of the relevant oils of the day (2007) and their respective levels of zinc and phosphorus. It's a worthwhile read to understand the subject. If anyone is interested in seeing it, PM me your email address and I'll send it to you. I have looked online and can't find it.
Peter Brownhill
Peter Brownhill
Re: "Diesel" oil
They may be lying, sure wouldn't be the first time a corporate entity did that but I am not concerned, and will continue to use 4 quarts of the 15W-40 Rotella, and then top it up with 15W-50 Mobil 1. It seems to like it. I overfill it very slightly, and it seems to like that too; Maybe ~ just about an extra cup.
- kilrwail
Re: "Diesel" oil
The 15w40 Rotella scored very high in both Zn and P in 2007 - should be more than good enough if they haven't diluted it as they say.
Peter Brownhill
Peter Brownhill
- FiatMac
Re: "Diesel" oil
Found these test results by the Petroleum Quality Institute of America.
Test results Rotella T4 CJ4 spec oil purchased 8/10/2016
http://pqiadata.org/ShellRotellaT15W40.html
Test results for Rotella T4 CK4 spec oil purchased 3/30/2017
http://pqiadata.org/Shell_Rotella_T4_15W40_4192017.html
Essentially the same levels of Phosphorus and Zinc in each
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
78 124 Spider on the rotisserie
76 124 Spider parts car or possible Lemons racer
83 parts car
83 parts car
Re: "Diesel" oil
Apparently the whole thing is a kerfuffle, as we say. On to something else.
- Your car is a: 1972 spider 124
Re: "Diesel" oil
Great work thanks
