Just finished cutting new trunk boards and then carpeting everything and couldn't help but think it came out pretty well! Not bad for $20 of carpet from Home Depot. Now to mount and wire that stereo amp!
Still debating carpet on the battery box. Opinions?
New trunk boards and carpet.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
Re: New trunk boards and carpet.
I'd vote "no" on carpeting the battery box.
Kirk
Kirk
- aj81spider
I carpeted mine. I built a custom box around it because I have a battery disconnect and left a hole at the top to get to the disconnect. Here's what it looks like if that helps you make a decision.
A.J.
2006 Corvette
2006 Corvette
- DUCeditor
- Your car is a: 1977 FIAT 124 Sport Spider
- Contact:
Beautiful work, both of you!
How'd you fit, cut and attach it? (Gotta be more than just being clever!)
-don
-don
Italian motorcycles. An Italian car. An Italian wife. What more could a man desire?
Both of them look great! Well done.
I would go with the carpet cover.
do you glue it down? Velcro?...or just lay it in?
- aj81spider
On mine I used Velcro strips to hold the carpet to the plywood. They hold very well so the carpet doesn't move at all.
For the battery box I glued it to the wood as the box comes off as one assembly.
To cut and fit it I made cardboard templates. I basically got close with a large piece of cardboard, then taped smaller pieces to it following the contours of the trunk. I used that to cut out the plywood, then used the plywood as a template to cut out the carpet. Getting the cardboard right was fiddly. Leave the old plywood in the trunk as you're doing it to provide a solid base, as the cardboard starts to get floppy - especially as you tape more and more pieces to it that are following the contours of the trunk.
A.J.
2006 Corvette
2006 Corvette
- Texsardo
- Your car is a: 1978 Fiat Spider Convertible 1800
- Contact:
Great job. I'll be doing mine soon. But big question, what are electrical connections beside the drivers side of battery?
- Odoyle
Texsardo wrote:Great job. I'll be doing mine soon. But big question, what are electrical connections beside the drivers side of battery?
Trunk Light, it has a small bulb and housing that attaches to a clip.
Actually NOT the trunk light wire (that is a single wire much higher up).
Most of it is connections for a stereo amp I need to re-install. The fuse box I installed for various loads back there, the electric fuel pump, thew stereo amp, an electric antenna and whatever else I might add. To the left of the fuse box is a relay for the fuel pump. You can also just barely see the Ford inertia switch I put in the path to the pump mounted to the side of the battery box.
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
- Texsardo
- Contact:
Thanks, just wondering. Thought might be a complicated battery cut out. Anti theft. I routed one under dash of my 65 GOT. Switch off, car dead.
Users browsing this forum: No registered users and 12 guests
