Brakes good, new calipers, and new pads -- what causes squeaky wheels around turns and when slowing down.
Not sure if it's coming from the front or the rear.
like something is out of round squeak.
Brakes good -- squeaky wheels around turns
- Your car is a: 1982 Fiat 124 Spider
Re: Brakes good -- squeaky wheels around turns
Dragging e-brake? Loose front bearings?
thanks ... i'll check for both.
Is there any pulsating in the brake pedal?
No almost none to minimal....
- Your car is a: 1975 Spider
Some things to consider...
Front Bearing freeplay excessive?
Are your sliders lubricated or installed dry?
Are the leading edges of the pads beveled? if not, do so with a file.
Anti-squeal pad on the backing plate?
If not, there are some permatex products to spray on the backing plate, let dry to tacky, then install.
I will be checking all that you mentioned in your post.
Thank you
Thank you
Steel rotor squeaking or tire squeal? Could be alignment issues or worn front suspension if its tire noise. If its brakes look at loose/worn front wheel bearings. It would be rare for rear wheel bearings to have that much effect but it would not hurt to check.
Here is a great video on how to properly pack a front wheel bearing. Many times front wheel bearings fail because they were not packed correctly as show here by Dan Anderson of the American Farm Journal:
https://www.youtube.com/watch?v=BhL1uAp_WCw
Users browsing this forum: No registered users and 23 guests
