Just saw this on the oreilley site. 5 quarts plus a filter for $9.99 plus $5 gift card, unless I am reading it wrong.
http://www.oreillyauto.com/site/c/MobilSuperConvPlusBonusOffer.oap?icid=intFlashMobileSuperBonus0212
I will be buying a couple cases worth, even if I have to go to a few different stores.
The microguard filter is a rebadged fram filter, so it should probably not be used.
Oil and filter $9.99 plus $5 gift card
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
Re: Oil and filter $9.99 plus $5 gift card
Link didn't work. I'll try doing a search.
What do you mean by "The microguard filter is a rebadged fram filter, so it should probably not be used." ?
Giulio/Charlotte
- ga.spyder
I think the way that works is that your out of pocket is $9.99.I believe you pay 14.99 and then you are sent the $5.00 card.Still a good deal.There are only a few filter mfg.,so many are rebadged from the same source.Here is an article by baltobernie,testing the filters for Fiat Spiders.Great article!
http://dcfiats.org/tech/filter-B.pdf
Craig Nelson
Fling It Around Turns !
- giuliot60
Thanks. I'll check it out.
Giulio/Charlotte
This deal was from 4 months ago (no longer available). Just received my gift cards last week, an effective cost of $1 per quart. I also used some cam shield with the oil.
- giuliot60
Thanks Derek. I guess it would make sense to look at the post date.
Giulio/Charlotte
Users browsing this forum: No registered users and 27 guests
