I found crimp terminals for our cars at vintageconnections.com
They are brand new from Japan. Apparently they were also used on Hondas of the 70s. They are the latching type, exactly the same as the stock Fiat ones that snap into the plastic block plugs. Very handy if you need to replace some. They are very very tight fitting. Makes you worry about all of your old connections.
They also sell a crimper that is meant for these connectors, but mine that I had laying around worked fine. Just make sure you have a crimper for non-insulated terminals.
Zulu
Crimp Terminals
Re: Crimp Terminals
Thanks, Ive been searching for some great crimp terminals for the past couple weeks. Can't wait to crimp, solder, and heat shrink these terminals.
Users browsing this forum: No registered users and 32 guests
