My driver's seat cushion was sagging badly because the webbing suspension strap across the seat base had disintegrated . The foam rubber cushion was still in good shape so I tried to find a replacement for the strap . .The only rubber webbing I could find was not strong enough . I replaced it with 3 inch wide wooden slats made from 1/4 inch ply . I used two slats across the seat bottom supported on three sides by the base with a third slat running fore and aft across the mid point of the base .
I now have a firm driver's seat base cushion.
Maxdog
Sagging driver's seat , cheap fix
- Patron 2019
- Your car is a: 1979 spyder 124
- geospider
Re: Sagging driver's seat , cheap fix
great idea. plexiglass should work as well. wondering how thick; need/want some spring. a new project; but motor first
geo
geo
- Patron 2019
My system allows you to fix the seat base without dismantling the seat . I managed to wiggle the 10 1/2 inch long x 3 inch wide 1/4 inch thick plywood strips into place through the hole in the base . Seat fixed at zero cost !
Cheers
Maxdog
Cheers
Maxdog
Users browsing this forum: Google [Bot] and 21 guests
