Seat Belts
Seat Belts
I have my original seat belts and it takes a few minutes just to put them on because you have to pull VERY slowly to avoid locking them up. So my question is, where do you all buy your seat belts from?
1979 Fiat Spider 2000 (carbureted) (rolling restoration after 10 years of sitting)
Re: Seat Belts
Seatbelt Planet. Good folks in Oklahoma. They have a Fiat Spider kit for a little over $200. My new belts work great.
Kirk
Kirk
- Your car is a: 1981 Fiat 124 Spider FI
Re: Seat Belts
Seatplanet seat belts, are they the right length? They use to make them with the wrong length.
- Your car is a: 1981 124 Spider
Re: Seat Belts
Replaced mine several years ago with belts from Wesco Performance. Tan color is a little darker than original but they fit just like the originals.
http://wescoperformance.stores.yahoo.net/seatbelts.html
Steve Muzzillo
1981 124 Spider 2000 (ex-turbo)
2006 Acura MDX
2008 Honda CRV
2014 GMC Acadia
2017 Acura RDX
2006 Acura MDX
2008 Honda CRV
2014 GMC Acadia
2017 Acura RDX
Re: Seat Belts
The length on my belts from Seatbelt Planet seems just fine. I believe it's within an inch or two of the originals that I pulled out. They make them to order, so I'm sure you can get any length you want. I ended up getting a set of plastic sleeves from them later to protect the belts where they bolt to the side rails of the floor pan. This was a good improvement and makes them easier to grab. I still need to get a set of belt guides that attach to the head rest posts.
Kirk
Kirk
- 1983Pinin
- Your car is a: 1983 Pininfarina
Re: Seat Belts
Can someone here tell me if on an '893 Spider the belt feeds up from the spool or down? I didn't pay attention when I pulled the old ones and the spool can mount either way. I have a feeling pulling down is the wrong way..
--Peter
1960 something 850 Spider in 1974-1976
1970 something 124 Spider 1977-1980
Currently 1983 Spider 2000
Re: Seat Belts
On my '82, the belt feeds out from the top of the spool.
Kirk
Kirk
Users browsing this forum: No registered users and 23 guests
