To those with more knowledge than me:
replacing:
ball joints, front bushings, springs, shocks
centerlink, tie rods.
wheel bearings
any good order or just pull it all apart
Geo
Front end: ALL
- geospider
Re: Front end: ALL
Most agree that it is the easiest and most cost effective approach in a total front end rebuild to buy 4 new control arms with the ball joints already installed.
Re: Front end: ALL
And just where do you find the control arms, non to be found,unless finally some one got a shipment
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Front end: ALL
They regularly come in to the various vendors, are you saying that they are all out at the moment?
Re: Front end: ALL
Back to geospider's original question, I just pulled it all out and put it back in in reverse order. I don't think there are any tricks concerning sequence. While you have it all out, be sure to check the engine cross member for cracks and the shock towers for rust. Check crossmember bolts for tightness. You should also check steering box for play and the condition of the steering idler. Don't forget sway bar bushings. I bought a good quality 1/2" drive, electric impact wrench and set of impact sockets from Harbor Freight. Great for suspension work.
Kirk
Kirk
- lglade
Re: Front end: ALL
Be sure to give your steering gear a good once over (fresh fluid and adjustment) when you have everything apart. Same goes for the steering idler on the passenger side. Everything has to be in good order to achieve a good outcome.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
- geospider
Re: Front end: ALL
thanks for all the replies.
was planning the whole A arm replacement, but as mentioned can't find the ones that fit well.
so now more self education with replacing the bushings, etc.
Rust, strut towers: I am lucky, Ca car: no rust. although smog was a PITA.
geo
geo
- Your car is a: 1985 pininfarina spider
control arms
fiat218 wrote:And just where do you find the control arms, non to be found,unless finally some one got a shipment
the company who made the arms seems no to want to anymore
the only new set in the USA are at
http://www.spiderroadster.com/124suspension1.htm
Users browsing this forum: No registered users and 3 guests
