I have both control arms taken off. Took them to the car wash and cleaned them up. Getting ready to take an air hammer chisel to the rivets on the lower ball joints.
My question. I purchased new ball joints and they came with bolts for both the upper and lower. I have always thought that the lower needed to be riveted? Evidently I was wrong.
Can someone tell me what the torque should be for the bolts on the upper and lower ball joint? And have you had any experience with the bolted lower ball joint?
Thanks for any advice you can give,
jb
79 2000 Replacing ball joints
- Your car is a: 1979 Spider
Re: 79 2000 Replacing ball joints
perfectly normal for ball joints to be bolted.
screws need to be 8.8 or 10.9
torque around 45 ft lb
Users browsing this forum: No registered users and 25 guests
