Headlights will not come on
- Your car is a: 1977 fiat 124 spider
- Contact:
My headlights will not come on,I checked all fuses,replaced headlight switch and new headlights ,only running lights come on but when I switch to headlights nothing comes on including running lights.Any suggestions would be appreciated.my next step is to replace ignition switch
Re: Headlights will not come on
Check your ground terminals
also post in the electrical section you will get more help/info
It might be a good time to re-wire the power to the headlights with a relay. This will make your lights brighter, as it will remove the power that now runs through your ignition switch. Also it will help increase the longevity of the ignition switch. Win,win!
Dave.
Dave.
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
Return to “New Members / Introductions”
Users browsing this forum: No registered users and 29 guests
