New member...prima a arm problem
- Your car is a: 1975 fiat 124 spider
Hi guys, I installed the prima a arms on my 124 spider and the lower ball joints have movement when tightened all the way..when you wiggle the wheel side to side there is movement between the bottom of the spindle and the ball joint....i called tbe supplier for new ball joints and they sent frap units that do the same thing...I have learned the prima a arms are lada fiat clone parts..still not sure why the ball joints dont tighten up..the car slides when you try to turn ..the stud on the ball joint does get tight in the spindle bottom...just wondering if anyone else encountered this problem..thanks guys..Jamie
Re: New member...prima a arm problem
Thanks to Frank at Ricambi and Matt at Vicks for helping..I will let you know hot it works out..its good to have a forum for the strange things that hsppen with these cars..
Return to “New Members / Introductions”
