AC Delco Coil
Moderator: So Cal Mark
AC Delco Coil
Postby naranjas on Tue Mar 09, 2010 6:13 pm
I've got a '79 and I suspect the coil is dying. When I turn the key sometimes the engine light does not come on. When this happens it will crank but not start. Occasionally it will die while I'm driving. When I search for a coil an AC DELCO one comes up and it costs less than $30. Has anyone ever tried one of these?
naranjas
Re: AC Delco Coil
Postby Mathew26 on Tue Mar 09, 2010 6:21 pm
I'm sure that would work ok. As long as the power matches to the Fiat it really should be fine, but you can find Bosch and Marelli ones. Also it may be your magnetic pickup (pickup coil) or possibly a control module issue.
Matt Phillips
1979 Fiat Spider 2000
Vick AutoSPORTS
http://www.vickauto.com
info@vickauto.com
Mathew26
Re: AC Delco Coil
Postby manoa matt on Tue Mar 09, 2010 6:23 pm
If its for a 79 then you need to have the correct coil with the correct primary and secondary resistances. Chances are the resistance measurements are not published for that coil.
This is the coil I'm running on my daily driver, no issues in 3 years, and has the correct resistances for the electronic breakerless system. http://www.summitracing.com/parts/ACC-8145/
The Fiat factory service manual has a great section for testing all the components of the electronic ignition systems, do that first.
manoa matt
Re: AC Delco Coil
Postby ga.spyder on Tue Mar 09, 2010 6:42 pm
I use that same coil as Matt(except chrome..bling!).A coil failure is not unheard of,but pretty rare.I had a issue last year that was very similar.I had just changed my ign. module,so I put the old one back in.Sure enough it fired right up.I dont know what shorted the 'high perf.' module out...stock unit is still in and running fine.Good luck
Craig
Craig Nelson
FLU board of directors
1981 Fiat X1/9
Fling It Around Turns !
ga.spyder
Re: AC Delco Coil
Postby So Cal Mark on Wed Mar 10, 2010 10:32 am
what engine light are you discussing? The red light in the bottom of the tach is for the charging system. I'm not aware of a light that indicates ignition
Mark Allison
http://www.allisonsautomotive.com LIghtweight gear reduction starters for the 124/131 Distributorless ignitions for 124, 131, X 1/9, ROTA wheels in stock!
Ultimate 124 Spider exhaust system,
Site Admin
Re: AC Delco Coil
Postby majicwrench on Wed Mar 10, 2010 5:14 pm
Everybody love to replace their coil. Im with Ga Spyder, coils hardly ever fail. And they have NOTHING to do with lights on the dash.
Back in the 70's, I got so tired of foks walking in and asking "can you check my coil??" that I built a little coil checker and started charging two bucks for the test. Over the years I probably checked over 200, and I must have found a bad one at some point, but I can't really remember.
majicwrench
Re: AC Delco Coil
Postby naranjas on Wed Mar 10, 2010 6:54 pm
It's the red light. More and more frequently it will not light up when I turn the key even though the starter cranks.
naranjas
Re: AC Delco Coil
Postby Tobi on Wed Apr 07, 2010 11:31 pm
OK, I am a bit late here but you should check on your ignition switch.
Tobi
Re: AC Delco Coil
Postby htchevyii on Wed Apr 07, 2010 11:39 pm
naranjas wrote:It's the red light. More and more frequently it will not light up when I turn the key even though the starter cranks.
My car's a late model EFI, but I had a bad ign switch that always cranked, but didn't always provide ign power. Come to think of it, my '72 ign switch failed too, but never provided ign power. Hook a jumper to the coil to bypass the switch next time it happends.
Trey
1982 SPIDER 2000, 1964 CHEVYII, 2005 DODGE RAM
New: 1972 Spider
htchevyii
Return to Engine and Tuning
Users browsing this forum: jfrawley and 1 guest
